Genesis440
Mar 28, 2023Aspirant
ORBI 750 ROUTER ,
I have only had this ORBI 750 ROUTER AND TWO SATELLITES A COUPLE WEEKS, I HAVE A NETRESET INSTALLED THIS RESETS YOUR MODEM AND ROUTER AT YOUR DETERMINED TIME OF DAY. I'VE NOTICED THAT AS THE NETRESET ...
- Mar 28, 2023
Genesis440 wrote:
i have a netreset installed this resets your modem and router at your determined time of day. i've noticed that as the netreset activates my modem restarts fine and then it restarts the routerCould you please provide more information about this netreset? I ask because people have asked on the forum, "How can I reset (or pause) my Orbi system at night?"
I agree entirely with Phyber that it is unusual to reset home WiFi systems these days. Mine remains up for months at a time until SoCal Edison entertains us with a power outage. This post appears to indicate that rather than somehow making the network "better", the netreset makes it worse. I would quit doing it.
Mar 28, 2023Guru - Experienced User
Ok no need to yell please.
Let's see if we can help you figure this out.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
