Genesis440
Mar 28, 2023Aspirant
ORBI 750 ROUTER ,
I have only had this ORBI 750 ROUTER AND TWO SATELLITES A COUPLE WEEKS, I HAVE A NETRESET INSTALLED THIS RESETS YOUR MODEM AND ROUTER AT YOUR DETERMINED TIME OF DAY. I'VE NOTICED THAT AS THE NETRESET ...
- Mar 28, 2023
Genesis440 wrote:
i have a netreset installed this resets your modem and router at your determined time of day. i've noticed that as the netreset activates my modem restarts fine and then it restarts the routerCould you please provide more information about this netreset? I ask because people have asked on the forum, "How can I reset (or pause) my Orbi system at night?"
I agree entirely with Phyber that it is unusual to reset home WiFi systems these days. Mine remains up for months at a time until SoCal Edison entertains us with a power outage. This post appears to indicate that rather than somehow making the network "better", the netreset makes it worse. I would quit doing it.
Genesis440
HI There,
Resetting is supposed to keep your internet connection optimal, it wouldn't matter if you do it daily or once a month, the fact is it isn't allowing my wifi devices to reconnect, my old Linksys EA 9500 router had no problem resetting daily so why does the Orbi?
Genesis440
HI There, the Netgear techs did everything everyone has posted via tech connected to my PC, they updated all the firmware and even changed channels from auto to a set channel, then even did a router reset and so far everything the techs have tried has not corrected this issue. I'm not. Network savvy, you guys know your stuff in this area I'm lost.
I'm going to keep having Netgear techs try to figure this issue out. Thank ALL of you !!
