Genesis440
Mar 28, 2023Aspirant
ORBI 750 ROUTER ,
I have only had this ORBI 750 ROUTER AND TWO SATELLITES A COUPLE WEEKS, I HAVE A NETRESET INSTALLED THIS RESETS YOUR MODEM AND ROUTER AT YOUR DETERMINED TIME OF DAY. I'VE NOTICED THAT AS THE NETRESET ...
- Mar 28, 2023
Genesis440 wrote:
i have a netreset installed this resets your modem and router at your determined time of day. i've noticed that as the netreset activates my modem restarts fine and then it restarts the routerCould you please provide more information about this netreset? I ask because people have asked on the forum, "How can I reset (or pause) my Orbi system at night?"
I agree entirely with Phyber that it is unusual to reset home WiFi systems these days. Mine remains up for months at a time until SoCal Edison entertains us with a power outage. This post appears to indicate that rather than somehow making the network "better", the netreset makes it worse. I would quit doing it.
CrimpOn
Mar 28, 2023Guru - Experienced User
Genesis440
Hi There, here is a link on Amazon where you can read about this reset system. I appreciate your input to, thank you, I might end up doing exactly what you are doing... just leave it alone and don't use the netreset device any longer.
Thank You Everyone !!
Steve
- FURRYe38Mar 28, 2023Guru - Experienced User
This would not be or should not be needed. If your having to reboot the system every so often then your not finding out what the real problem is as again, the system should not need to be rebooted or power cycled on a daily basis.
Maybe give feedback to the questions presented so we can try and help you out. If not, then make contact with NG support.
Were here to help you out is all. What the forums are for. Free support.
