Del85204
Nov 09, 2024Follower
Orbi 750 Series AX3000 Mesh Wi-Fi Router with 2 Satellites. Satellite not connecting
New to this product and learning every day. But I have one satellite that was connected but now doesn’t want to. Any suggestions to fix this? I’ve recycled the power and all.
Nov 09, 2024Guru - Experienced User
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
What channel configurations are currently set on the router?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Swap RBS locations or turn OFF the other RBS to see if you can get the other RBS to connect?
