laltaffer
Apr 19, 2022Aspirant
Orbi 750s lost satellite during firmware update
One of my satellites is no longer connecting. This started two firmware updates ago and I think the one sat didn't get updated. Now it won't sync or connect no matter which tool (app or website) I us...
- Apr 19, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Apr 19, 2022Guru - Experienced User
have you tried hardwiring it into the router?
laltaffer
I have it hardwired to the router. But it only shows up as a connected device, no different than my PS5. I got its IP address but none of the admin/PW combos seem to work. Took the one from the bottom of the satellite it won't work.
Any ideas on what to do next?
