laltaffer
Apr 19, 2022Aspirant
Orbi 750s lost satellite during firmware update
One of my satellites is no longer connecting. This started two firmware updates ago and I think the one sat didn't get updated. Now it won't sync or connect no matter which tool (app or website) I us...
- Apr 19, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Apr 19, 2022Guru - Experienced User
Be sure the RBS was updated first before the RBR.
- laltafferApr 19, 2022Aspirant
I have not done a full RBR + RBS factory reset. I have hit and held the RESET button on the RBS but that doesn't seem to have done much for me. Currently I don't see any way for me to check on the firmware of the RBS in question. It shows up as a wired connection but not as another satellite so it doesn't give me any more information than it does when showing my phone is connected.
The RBR and RBS that are working correctly are running V4.6.5.14_2.0.54To do a full factory reset do I need to unplug everything for a day? I think I read that somewhere and honestly not sure I can do that. I'd have to go get another set to run in the interim. If not what are the steps to do a factory reset?
Also its worth noting that the 'bad' RBS does occasionally do the white light blinking, which I have read means bad firmware.. I just have not found a way to get it connected so I can manually update it
- FURRYe38Apr 19, 2022Guru - Experienced User
Press the reset button the RBR and RBS for 15 seconds then release. Walk thru the setup wizard. I would wirelessly sync the RBS to the RBR with the RBR near or in same room as the RBR and ensure it syncs fully and the front BLUE LED turns OFF. Then place back in remote location.
You may want to consider updating FW as well:
Am I correct in thinking that if I do the reset I should do it with both RBS's and the RBR? Rather than just the 'bad' RBS and then RBR
