laltaffer
Apr 19, 2022Aspirant
Orbi 750s lost satellite during firmware update
One of my satellites is no longer connecting. This started two firmware updates ago and I think the one sat didn't get updated. Now it won't sync or connect no matter which tool (app or website) I us...
- Apr 19, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
laltaffer
Got it all working by updating the firmware first on the two devices I could update. Once that happened the second RBS showed up and already had the latest firmware.
Thank you for all of the help
Apr 19, 2022Guru - Experienced User
Enjoy. 📡
