Knine235
Mar 03, 2023Aspirant
Orbi 752- Magneta light
Hi, I have this morning tried to find a solution to clear the Magneta light which has suddenly appeared on both the Router and satellite. I have rebooted both several times - tried to run the...
Mar 03, 2023Guru - Experienced User
What modem/gateway do you have?
Knine235
Thanks Plemans - Phybers advice has got me back up and running.
- FURRYe38Mar 03, 2023Guru - Experienced User
Enjoy. 📡- Knine235Mar 04, 2023Aspirant
Great info.
Thanks
