Knine235
Mar 02, 2023Aspirant
Orbi 752- Magneta light
Hi, I have this morning tried to find a solution to clear the Magneta light which has suddenly appeared on both the Router and satellite. I have rebooted both several times - tried to run the...
Mar 03, 2023Guru - Experienced User
Enjoy. 📡
Knine235
Mar 03, 2023Aspirant
Great info.
Thanks
