fdelmo10
Jul 28, 2021Tutor
orbi 752
is there a way to manually add a device to a specific satellite. It seems when my system stalls. my camera's connect directly to the orbi not the closest satelitte. They dont have the best signal the...
Jul 28, 2021Guru - Experienced User
I'ts up to devices to pick and choose where they connect too. Orbi can't force where they connect.
You can help some by trying the following:
Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
