MaleHumanUK
Apr 14, 2021Star
Orbi 753 - ‘400 Bad Request’ on LAN settings
I have the Orbi 753. I am unable to save any changes to LAN settings, presented with a ‘400 Bad Request’ screen. Accessing settings via 192.168.1.1, and using menu option Advanced -> Setup -> LAN S...
- Apr 15, 2021The issue was present on the v3.2.17.x firmware. Whilst on that firmware I tried a factory reset of all units to solve the issue, but it did not resolve it.
Yesterday I updated to the v3.2.18.1 firmware. The issue remained. Whilst on this firmware I today performances a factory reset of all units; that resolved the issue.
So issues existed on both firmwares; but whilst a factory reset did not help whilst on v3.2.17.x, it did resolve the issue on the new v3.2.18.1 firmware.
Thanks for the support from everyone.
Blanca_O
Apr 15, 2021NETGEAR Employee Retired
Hi MaleHumanUK
Thank you for the update. Glad to know that it is now sorted out.
Just to clarify, you mentioned on your initial post that issue is present on the 3.2.17.x firmware, and the new 3.2.18.1. And that the issue was fixed after updating the firmware. Did you reflash the firmware v3.2.18.1?
Looking forward to your response.
Blanca
Community Team
- MaleHumanUKApr 15, 2021StarThe issue was present on the v3.2.17.x firmware. Whilst on that firmware I tried a factory reset of all units to solve the issue, but it did not resolve it.
Thanks for the support from everyone.- FURRYe38Apr 15, 2021Guru - Experienced User
Please mark your thread as solved so others will know. Be sure to make a backup configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. :smileywink:
