fadersnstuff
Mar 28, 2022Aspirant
Orbi 753 and Open VPN - has anyone managed to make this work for a mac laptop??
I've been battling with the VPN server in the orbi for some time now. If I tether my mac laptop to my phone at home in the UK running on data I can connect via tunnelblick. If I'm on an external netw...
CrimpOn
Apr 04, 2022Guru - Experienced User
Can you please explain "teather". Does that refer to:
- Physically connect the laptop to the iPhone, or
- Create a WiFi Hot Spot on the iPhone and connect the laptop to it?
On my (old) RBR50, the smart_phone.zip file contains one file named "smart_phone.ovpn". There is no file named "client.ovpn". Perhaps in their infinite wisdom Netgear decided to rename the ovpn file for the RBR750 series?
I've attached my smart_phone.ovpn file. Does your client.ovpn have the same sections as mine?
client
dev tun
proto udp
remote myDDNSname.mynetgear.com 12973
resolv-retry infinite
nobind
persist-key
persist-tun
<ca>
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
</ca>
<cert>
Certificate:
Data:
Version: 3 (0x2)
Serial Number: 2 (0x2)
Signature Algorithm: sha256WithRSAEncryption
Issuer: C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=netgear CA/name=EasyRSA/emailAddress=mail@netgear
Validity
Not Before: Jul 13 19:33:02 2018 GMT
Not After : Jul 8 19:33:02 2038 GMT
Subject: C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=client/name=EasyRSA/emailAddress=mail@netgear
Subject Public Key Info:
Public Key Algorithm: rsaEncryption
Public-Key: (1024 bit)
Modulus:
00:d6:29:ce:29:61:81:18:a4:ea:31:9b:e7:21:7a:
53:e8:4d:41:c0:13:e9:80:b7:9a:7e:d8:62:fe:7b:
7b:01:c0:2c:13:b8:36:44:44:ad:20:19:cc:79:3d:
af:73:68:74:60:bb:14:d6:32:1b:4d:34:88:57:82:
b4:e1:6a:ac:88:62:01:d4:f1:58:54:4a:0c:00:7a:
e9:01:7b:67:d9:d7:a6:cb:1d:9a:23:fd:0b:52:a6:
6a:05:25:40:38:79:06:20:71
Exponent: 65537 (0x10001)
X509v3 extensions:
X509v3 Basic Constraints:
CA:FALSE
Netscape Comment:
Easy-RSA Generated Certificate
X509v3 Subject Key Identifier:
ED:01:3E:B4:0B:F3:BA:F9:D8:55:56:9F:A4:80:35:89:C7:F5:DE:15
X509v3 Authority Key Identifier:
keyid:7F:26:F7:0D:1A:DF:DB:DF:49:2D:AC:33:63:A7:6D:92:2B:6D:AA:ED
DirName:/C=TW/ST=TW/L=Taipei/O=netgear/OU=netgear/CN=netgear CA/name=EasyRSA/emailAddress=mail@netgear
serial:FD:7E:A8:2F:9C:3E:F8:85
X509v3 Extended Key Usage:
TLS Web Client Authentication
X509v3 Key Usage:
Digital Signature
e4:9b:e2:54:9a:b4:5f:2b:4d:18:d7:bd:c8:31:66:59:e6:36:
30:f9:44:bb:06:f0:53:43:3c:c4:ff:4b:85:af:a4:f7:de:41:
11:d7:0d:75:96:28:f8:fc:9d:95:76:71:39:e5:d8:62:5f:a3:
da:4e:49:fa:c2:65:8b:23:b6:97:5c:bd:df:58:d2:22:cf:61:
90:8b:36:b9:84:62:a3:00:0c:91:4b:36:72:df:91:f8:3f:1a:
1a:e8:62:5f:17:19:91:04:65:3e:a2:f6:a6:50:1c:6e:a8:9e:
2b:5c
B0Vhc3lSU0ExGzAZBgkqhkiG9w0BCQEWDG1haWxAbmV0Z2VhcjAeFw0xODA3MTMx
OTMzMDJaFw0zODA3MDgxOTMzMDJaMIGPMQswCQYDVQQGEwJUVzELMAkGA1UECBMC
VFcxDzANBgNVBAcTBlRhaXBlaTEQMA4GA1UEChMHbmV0Z2VhcjEQMA4GA1UECxMH
bmV0Z2VhcjEPMA0GA1UEAxMGY2xpZW50MRAwDgYDVQQpEwdFYXN5UlNBMRswGQYJ
KoZIhvcNAQkBFgxtYWlsQG5ldGdlYXIwgZ8wDQYJKoZIhvcNAQEBBQADgY0AMIGJ
AoGBANYpzilhgRik6jGb5yF6U+hNQcAT6YC3mn7YYv57ZkdaPDRBTtbs+ocvuY4o
XkSA6+aD0RNriCtbyx9VewHALBO4NkRErSAZzHk9r3NodGC7FNYyG000iFeCtOFq
rIhiAdTxWFRKDAB66QF7Z9nXpssdmiP9C1KmagUlQDh5BiBxAgMBAAGjggFKMIIB
RjAJBgNVHRMEAjAAMC0GCWCGSAGG+EIBDQQgFh5FYXN5LVJTQSBHZW5lcmF0ZWQg
Q2VydGlmaWNhdGUwHQYDVR0OBBYEFO0BPrQL87r52FVWn6SANYnH9d4VMIHIBgNV
L5w++IUwEwYDVR0lBAwwCgYIKwYBBQUHAwIwCwYDVR0PBAQDAgeAMA0GCSqGSIb3
DQEBCwUAA4GBABAJVRifewYH7D60p2Nuo8wv2uSb4lSatF8rTRjXvcgxZlnmNjD5
RLsG8FNDPMT/S4WvpPfeQRHXDXWWKPj8nZV2cTnl2GJfo9pOSfrCZYsjtpdcvd9Y
0iLPYZCLNrmEYqMADJFLNnLfkfg/GhroYl8XGZEEZT6i9qZQHG6onitc
</cert>
<key>
-----BEGIN PRIVATE KEY-----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-----END PRIVATE KEY-----
</key>
cipher AES-128-CBC
comp-lzo
verb 5
