IvoK
Mar 09, 2022Tutor
Orbi 753 daily hick ups
Hello community - since October, I have an ORBI RBS753 system. Since February, the system has daily hick ups: it is not connected to the internet. The hick ups are 10 seconds to a minute. I have a B...
- Mar 09, 2022
You might try this version of the firmware if this just started in febuary:
I'd recommend installing the firmware and then doing a factory reset/reinstall (not from a backup)
IvoK
Mar 09, 2022Tutor
The ORBI app says there is no new firmware available at this time. Should I still go ahead and install the update manually?
Mar 09, 2022Guru - Experienced User
I would.
I know its been pushed out for the 8 series with it helping but it hasn't been released to the official channels for the 7 series yet.
