zhuch07
Sep 09, 2021Follower
Orbi 753 drops internet connections every few days, unplug plug connection to modem fixes it
(Reposting from https://community.netgear.com/t5/Orbi/Orbi-753-drops-internet-connections-every-few-days-unplug-plug/m-p/2137874/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufEtUQ1pRVkZVOFU0OVc4fDIxMzc...
Sep 09, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
ezpzDUDE
Dec 04, 2021Guide
I noticed that the user did not reply to your questions regading the issue of the RBK753S dropping internet connection.
I have had three call in regarding this issue. And our connection drops throughout the day. I noticed that this issue popped up in 2020 and the suggestion was to upgrade to beta firmware. My unit has been upgraded twice per the suggestion of Premium Support. And there has been no improvement and in fact, upload has slowed down considerably.
I am beginning to suspect that the Orbi line has some issues and that I should return this for something else? Or are there any suggestions please? Thank you
My current fw is V4.6.5.14_2.0.54
My unit is RBK753R-100NAS with two RBK753S units
- FURRYe38Dec 05, 2021Guru - Experienced User
Yes, there are some issues with current FW on Orbi systems. NG IS aware.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
- ezpzDUDEDec 05, 2021Guide
Hi Furrye38,
First, Thank YOU. I have read so many posts in the NETGEAR COMMUNITY and most seem to be answered by you. So in case anyone who was grateful has not said so, well, I am grateful, and so Thank YOU.
And thank you for the update. BTW, do you have any suggestions on a network monitoring software I can set up on one of my Macs to record / track the number of times the network drops as well as distinguish between when the ISP has an interruption vs my local network, please? Thank you
BTW, for some reason, Model section won't allow me to save:
Model: RBK53|Orbi AC3000 Tri-band WiFi SystemNor is this RBK available in the pull down- FURRYe38Dec 06, 2021Guru - Experienced User
Was your problem resolved or is it still happening.
Not ware of any end user SW that monitiors drops in connections or tell between an ISP issue or local network issue.
ezpzDUDE wrote:
Hi Furrye38,
