theguptas
Mar 31, 2021Guide
Orbi 753 unencrypted 5ghz network even though WPA2 security is turned on
Hi Everyone, I have searched through the forum and seen other people have similar issues but briefly 1) RBK753, satellites setup with ethernet backhaul, router running in AP mode 2) from day 1...
Mar 31, 2021Guru - Experienced User
So take a RBS to the same room or near the RBR and use a LAN patch cable and wireless sync the RBS to the RBR, the after that, connect the RBS to the RBR. It should sync correctly and check the RBS satus page. Let us know if this happens.
My two are fully wired:
theguptas
Mar 31, 2021Guide
Ok. Will give that a shot. Btw, are your satelllites wired directly to the router ie star topology or are going via a switch ?
Thanks
- FURRYe38Mar 31, 2021Guru - Experienced User
Behind Switches. NG GS 108 and 105 series. I have a 108 behind the RBR. For the one in the DiningRoom, There is a 2nd switch after the 108 switch. For the one in the BaseMent, There are two 105s after the 108 with the RBS in be basement connected to a 105 there. Been working like this for years. I actually had 3 switchs in between the RBR and basement RBS however I was able to elliminate 1 switch last year.
- theguptasApr 01, 2021Guide
Cool. I have a NG GS 108E and GS 105E2 as well. The NG GS108 is next to the xfinity cable model router and the GS105 is next to a satellite/home computer where I needed more ethernet ports
I will give this a shot today
- FURRYe38Apr 01, 2021Guru - Experienced User
Mine are the non E version however....Wonder if these E versions are somehow different
