theguptas
Mar 31, 2021Guide
Orbi 753 unencrypted 5ghz network even though WPA2 security is turned on
Hi Everyone, I have searched through the forum and seen other people have similar issues but briefly 1) RBK753, satellites setup with ethernet backhaul, router running in AP mode 2) from day 1...
Apr 06, 2021Guru - Experienced User
How is the RBR connected to the ISP modem/router? WAN or LAN port on the RBR to the ISP modem?
Seems like the RBS isn't getting an IP address from the ISP Modem correctly or the modem isn't giving an IP address to the RBS.
gerald732 wrote:
I can’t seem to sync wirelessly in AP mode. It’s doable if the Router isn’t in AP mode. Since, I cannot run my ISP modem/router in bridge mode, I’ll need to run the Orbi in AP mode.
I’ve tried resetting both the devices to factory setting as well, but to no avail.
Let me try pushing the security settings out with the toggle between wpa3 and wpa2
theguptas
Apr 06, 2021Guide
FURRYe38 is spot on. Once you put the Router in AP mode, you have to change your ISP internet connection cable from WAN port (yellow) to one of the other LAN ports.
That was my original setup, although I had jumped straight ethernet backhaul for the sateliites where the satellites were able to sync right away to the Router, each one of them having obtained a DHCP address from the ISP cable model/Router box
- FURRYe38Apr 06, 2021Guru - Experienced User
I took my Orbi 850 series and put it into AP Mode. I let the RBS850 wirelessly connect first then Ethernet connected them behind the RBR. RBR850 is connected to a NetDuma R2 router.
For a short period, say 5-10 seconds I did see on 1 RBS850s web page reported Security Type as NONE. However after refreshing the page afterwards, the Security Type did change to WPA2/AES.
One thing I'm curious about, both RBS are reporting Up to 800/2167 for there Wireless Mode. I beleive there supposed to be 1200/2400 on there front haul radios as per the data sheet:
• Orbi AX6000 Router and AX6000 Satellites
(2400 + 2400 + 1200Mbps)†The RBR is reporting 1147/2400:
Any one else see this on there RBS?
Ok, this is the same issue as seen on the 7 series. :smileyembarrassed: Will be fixed on next FW update.
