theguptas
Mar 31, 2021Guide
Orbi 753 unencrypted 5ghz network even though WPA2 security is turned on
Hi Everyone, I have searched through the forum and seen other people have similar issues but briefly 1) RBK753, satellites setup with ethernet backhaul, router running in AP mode 2) from day 1...
Apr 07, 2021Guru - Experienced User
This user was able to get this going:
I suggest you try this as well.
fangruoyuan
Apr 07, 2021Guide
I think more people will join this discussion unless NG fix it. Since orbi ax 3series and 7series is on sale now, and I think they share some core codes in the firmware with 8series. With more orbi ax series, more people will find this issue.
- FURRYe38Apr 07, 2021Guru - Experienced User
Until they do, you seem to be the only one. Again, Try what other users have done or contact NG support.
Good Luck.
