theguptas
Mar 31, 2021Guide
Orbi 753 unencrypted 5ghz network even though WPA2 security is turned on
Hi Everyone, I have searched through the forum and seen other people have similar issues but briefly 1) RBK753, satellites setup with ethernet backhaul, router running in AP mode 2) from day 1...
fangruoyuan
Apr 09, 2021Guide
NG support think it might be something with my wifi password . I have a @ in it. Do you have any symbol in your WiFi password?
Apr 10, 2021Guru - Experienced User
That would be one possible cause.
So did you remove the special character from the PW and what were the results?
Try a simple 6-15 alpha character only password to see if the RBS completes and syncs correctly with correct security status?
I don't use special characters on mine.
