midnightbui
Aug 28, 2020Aspirant
Orbi 753 wired backhaul question how to
Possibly a noob question on best setup for my orbi with two satellites. Two story home has main internet coaxil in master bedroom closet. So modem connects there, orbi router connects to modem. so...
Aug 29, 2020Guru - Experienced User
It's best to have the switch come first, then RBS lastly.
What is the mfr and model# of this switch? Some switchs can cause problems between RBR and RBS.
Do you have all the remote wired rooms going to one location? IF so, your wired configuration could look like this:
ISP Modem> Orbi AX RBR>Switch><Wired rooms to switch<>RBS connected to wall jack in remote room location.
You can do:
ISP Modem> Orbi AX RBR><Wired rooms to RBR>Swithch<>RBS connected to a switch in the remote room location.
midnightbui
Sep 04, 2020Aspirant
its a netgear 8 port Gig Model GS208 unmanaged
