midnightbui
Aug 28, 2020Aspirant
Orbi 753 wired backhaul question how to
Possibly a noob question on best setup for my orbi with two satellites. Two story home has main internet coaxil in master bedroom closet. So modem connects there, orbi router connects to modem. so...
midnightbui
Sep 11, 2020Aspirant
What Firmware version is currently loaded? ORBI Firmware version: v3.2.16.6
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? It is connected to a Netgear CM1100.
No other router, just the RBR router.
So Netgear CM1100 connected to RBR Router then connected to switch. So what can cause doublenat when i am only connected to one router.
Sep 11, 2020Guru - Experienced User
You should see any double NAT issues since your in a single NAT configuration.
What is the mfr and model# of this switch your using?
Where are you seeing this double nat problem?
- midnightbuiSep 17, 2020Aspirant
I have a netgear GS208 8-port unmanaged switch.
Double Nat error is through my XBox Network setting. Showing double nat detected
I am really frustrated. Xfinity came twice and supposedly fixed internet problem but it is still bad.
I am reading this forum and have been messing with my router settings to see if it will help but nothing. If its not too much to ask, can you or someone tell be the optimal setting i should have on my router. Thanks
- FURRYe38Sep 17, 2020Guru - Experienced User
Does changing the manual port number on xboxes advanced networking settings change anything?
Would be good if you can connect the xbox directly to the RBR to make sure the switch isn't doing anything. Can you wirelessly connect the xbox for a short period of time after holding the power button on the front of the xbox until it turns off then turn it back on.
- midnightbuiSep 18, 2020Aspirant
To me, changing the ports on the Xbox does nothing. Same thing. When i go wireless it would give me the same lag and high latency. Im having Xfinity come out for the 3rd time. I feel my network setup is right and that it is not my hardware.
What seems strange is everything including my xbox would work perfectly fine with no double nat showing up on the xbox but then after 10-15 minutes it would give that error. Again i really think it is my ISP
- FURRYe38Sep 18, 2020Guru - Experienced User
Ok, if your seeing OPEN NAT at the beginning, then it changes, then this would be an ISP/ISP modem issue.
One thing to try, connect the xbox directly to the ISP modem. Let the xbox sit and check the NAT status. I presume if it changes from OPEN to something else, this will prove to the ISP it's there problem.
