midnightbui
Aug 28, 2020Aspirant
Orbi 753 wired backhaul question how to
Possibly a noob question on best setup for my orbi with two satellites. Two story home has main internet coaxil in master bedroom closet. So modem connects there, orbi router connects to modem. so...
Sep 17, 2020Guru - Experienced User
Does changing the manual port number on xboxes advanced networking settings change anything?
Would be good if you can connect the xbox directly to the RBR to make sure the switch isn't doing anything. Can you wirelessly connect the xbox for a short period of time after holding the power button on the front of the xbox until it turns off then turn it back on.
midnightbui
Sep 18, 2020Aspirant
To me, changing the ports on the Xbox does nothing. Same thing. When i go wireless it would give me the same lag and high latency. Im having Xfinity come out for the 3rd time. I feel my network setup is right and that it is not my hardware.
What seems strange is everything including my xbox would work perfectly fine with no double nat showing up on the xbox but then after 10-15 minutes it would give that error. Again i really think it is my ISP
