midnightbui
Aug 28, 2020Aspirant
Orbi 753 wired backhaul question how to
Possibly a noob question on best setup for my orbi with two satellites. Two story home has main internet coaxil in master bedroom closet. So modem connects there, orbi router connects to modem. so...
midnightbui
Sep 18, 2020Aspirant
To me, changing the ports on the Xbox does nothing. Same thing. When i go wireless it would give me the same lag and high latency. Im having Xfinity come out for the 3rd time. I feel my network setup is right and that it is not my hardware.
What seems strange is everything including my xbox would work perfectly fine with no double nat showing up on the xbox but then after 10-15 minutes it would give that error. Again i really think it is my ISP
Sep 18, 2020Guru - Experienced User
Ok, if your seeing OPEN NAT at the beginning, then it changes, then this would be an ISP/ISP modem issue.
One thing to try, connect the xbox directly to the ISP modem. Let the xbox sit and check the NAT status. I presume if it changes from OPEN to something else, this will prove to the ISP it's there problem.
