dtay
Jun 14, 2020Luminary
Orbi 753S (AX4200 3-pack) or 842 (AX5700 2-pack)?
I'm looking to upgrade to an Orbi Wi-Fi 6 system, either the 753S (3-pack, AX4200) or the 842 (2-pack, AX5700), both which are sold at Costco. Roughly 45+ devices (23 @ 2.4 GHz, 14 @ 5 GHz, and 1 @ 5...
McLong
You may want to skip the Costco packs with your house layout and go for the 853 AX6000. The 3 pack from Costco ax4200 will probably work for you but you lose 1200mpbs on the frontend 5ghz channel. I recommend you get the right system as performance is one of your main objectives. Both systems will be stable but the 853 will be the better choice in the long run as you introduce multiple AX devices into your network.
- dtayJun 14, 2020Luminary
McLong wrote:
You may want to skip the Costco packs with your house layout and go for the 853 AX6000. The 3 pack from Costco ax4200 will probably work for you but you lose 1200mpbs on the frontend 5ghz channel. I recommend you get the right system as performance is one of your main objectives. Both systems will be stable but the 853 will be the better choice in the long run as you introduce multiple AX devices into your network.The 853 is just too expensive for my budget, at $1K and it's sold out everywhere.
The two pack (852) is $700; so basically it's $300 for a satellite.
OUCH!
