6172crew
Jan 14, 2021Guide
Orbi 753S (costco) and the amazon echo or google dot
I have seen a few others having issues with getting the smart speakers to play, or stream but none of the issues are mine and I see no fixes. I have fiber to the prem, 250mbps and use my Orbi for wi...
6172crew
Jan 15, 2021Guide
I turned my orbi into a AP, and still have issues. No specific Network Address Translation buttons that I can see but my orbi plugs direectly into the calix fiber to prem modem. I am not using a switch, or any other devices. All of my smart home stuff is on my guest network, with a total of 14 devices.
vajim
Jan 15, 2021Master
another possible option:
use the orbi router ONLY
get rid of whatever other router you're using IF you can
- 6172crewJan 15, 2021Guide
I don't think I can do that, but I will try. It isn't a cable modem so maybe I can bypass it. I do have that wifi turned off atm, but the gui for it is pretty much locked down to customers. The login from the tech didn't work but I was able to find it on google and able to get in and at least turn on and off the wifi signal so it wont mess with my 753s signals.
