6172crew
Jan 14, 2021Guide
Orbi 753S (costco) and the amazon echo or google dot
I have seen a few others having issues with getting the smart speakers to play, or stream but none of the issues are mine and I see no fixes. I have fiber to the prem, 250mbps and use my Orbi for wi...
6172crew
Jan 15, 2021Guide
it is a Calix gig router, a GS2020 most likely. When I logged into it last night it brings up a customer side to be able to turn on and off the wifi, and sends to you a wizard, but gives no options to play around with anything else so i might need to call uo the local provider and see if they can do more. Issue is the amazon echo works fine using the ISPs wifi, so it certainly points towards netgear orbi as the problem and there are a few members here complaining about the same thing. I do notice the echo isn't connected to the closest satellite upstairs which is odd but its able to tell me the time and weather, just wont stream or it buffers really bad, or it wont continue at all. I just moved into my home, so I am busy with other things and can't spend the time with customer support. Like some, I work in the industry and have done some basic troubleshooting before joining this forum. Only thing I have not tried is moving the smart speaker deals over to the non-guest wifi.
Jan 15, 2021Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try setting CTS to 2347 on the RBR. Under Advanced Tab/Advanced Settings/Wireless Settings
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
Please visiting the Orbi AX forum as well.
Good Luck.
6172crew wrote:it is a Calix gig router, a GS2020 most likely. When I logged into it last night it brings up a customer side to be able to turn on and off the wifi, and sends to you a wizard, but gives no options to play around with anything else so i might need to call uo the local provider and see if they can do more. Issue is the amazon echo works fine using the ISPs wifi, so it certainly points towards netgear orbi as the problem and there are a few members here complaining about the same thing. I do notice the echo isn't connected to the closest satellite upstairs which is odd but its able to tell me the time and weather, just wont stream or it buffers really bad, or it wont continue at all. I just moved into my home, so I am busy with other things and can't spend the time with customer support. Like some, I work in the industry and have done some basic troubleshooting before joining this forum. Only thing I have not tried is moving the smart speaker deals over to the non-guest wifi.
- vajimJan 15, 2021Master
Please visiting the Orbi AX forum as well. :smileyhappy:
- 6172crewJan 15, 2021Guide
Thanks, I will dig deeper this weekend and give the above a try. At this time I am in AP mode, and I have been in the AX forum looking at the current threads about the same issue. Again; thanks for taking the time to sugggest a few things. I will report back what I find so others can get things working like they should.
6172crew wrote:Thanks, I will dig deeper this weekend and give the above a try. At this time I am in AP mode, and I have been in the AX forum looking at the current threads about the same issue. Again; thanks for taking the time to sugggest a few things. I will report back what I find so others can get things working like they should.
Good luck....:smileyhappy:
