GarryJKing73
Mar 15, 2024Aspirant
Orbi 760S Device / Network Uptime
For some reason the uptime displayed either within the router stats or the debug dont display the correct uptime, seems to think it only been up for 1 or 2 hours when in reality it hasnt been switche...
Mar 17, 2024Guru - Experienced User
Generally, single digits CPU values, to maybe low 10's or teens. I don't have this system so I can't make a great comparison but from others postings and my own other Orbi 750, 850 and 9 series, most of them all hang in the range I mentioned. If we seem to see a creep upwards into the 20s, 30s and beyond, this could be some bad behavior in the system and could lead to seeing bad behavior or if the CPU gets to high, means the CPU temp could be high as well and over time, will damge the unit. Lets try to avoid this if we can.
KevinLiT
Apr 12, 2024NETGEAR Moderator
Hello FURRYe38,
Thank you for the information on CPU load values. However, in this case the CPU that is seen by GarryJKing73 is expected.
Best,
Kevin
Community Team
Best,
Kevin
Community Team
- FURRYe38Apr 12, 2024Guru - Experienced User
Would like to know if thats with all Orbi features enabled, like Armor, SPC and Traffic Meter, IPv6 and maybe Guest Network all running at the same time? Just kind seems a bit high and I would presume if these features were not enabled, the CPU usage seems like would be much lower running normally.
