GarryJKing73
Mar 15, 2024Aspirant
Orbi 760S Device / Network Uptime
For some reason the uptime displayed either within the router stats or the debug dont display the correct uptime, seems to think it only been up for 1 or 2 hours when in reality it hasnt been switche...
KevinLiT
Apr 12, 2024NETGEAR Moderator
Hello FURRYe38,
Thank you for the information on CPU load values. However, in this case the CPU that is seen by GarryJKing73 is expected.
Best,
Kevin
Community Team
Best,
Kevin
Community Team
Apr 12, 2024Guru - Experienced User
Would like to know if thats with all Orbi features enabled, like Armor, SPC and Traffic Meter, IPv6 and maybe Guest Network all running at the same time? Just kind seems a bit high and I would presume if these features were not enabled, the CPU usage seems like would be much lower running normally.
