Tasrac
Dec 15, 2022Tutor
Orbi 850 and Arris SB8200
Wondering if the community can help. I have an Arris SB8200 modem. I subscribe to Ultimate 500mb down and 10mb up from Cox. When doing speed tests, I am only seeing about 90-95mb down on Wi-Fi as ...
Dec 15, 2022Guru - Experienced User
If your not seeing to spec speed when directly connected to the ISP modem with a PC with out Orbi in the mix, you'll need to contact your ISP and modem Mfr for help and information regarding this. This is on the ISP to ensure all is working well up to the modem.
Also test with a different PC to compare results.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Tasrac
Dec 15, 2022Tutor
Thanks. I am having Cox come down later today to troubleshoot). Before I had my Orbi 850, I used a Linksys router and had no problems with my internal speeds so the wiring is ok (Cat 5e supports up to 1 gb) As for the wi-fi (5g) the speed tests are coming in at under 100mb.
- FURRYe38Dec 15, 2022Guru - Experienced User
If wired speeds at the modem are low, then the same would be seen at the Orbi wifi as well.
Once the Modem and issues there are resolve and you finally get to spec speed there, you should see same thru the orbi system as well. The Orbi system can only provide as good as what the modem does.
- plemansDec 15, 2022Guru - Experienced User
Have you logged into the orbi to check its wan port statistics?
I've seen sketchy cables that'll connect at 1 gig on some devices an only 100mbps on others.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
(this is for nighthawk but will work on orbi too)
- TasracDec 15, 2022Tutor
Thanks for that. I just did and see this:
Not sure why WAN is showing 100M/Full though.
Try swapping in a cat 6 cable between the modem/router. Its auto negotiated and isn't connecting at gigabit speeds. Maybe the cat 5e cable has issues with that specific setup. Some devices are pickier than others.
