rschein
Apr 24, 2025Aspirant
Orbi 850 atopped wifi with wrong password
About 0200utc on apr 24. My orbi mesh dropped wifi with bad passwords (worked for years) I am in phoenix, my friend in la has the same issue started same time (or so) Different issues and equipmen...
Apr 24, 2025Guru - Experienced User
What do you mean by bad passwords?
What devices are being connected?
rschein
That is error when trying to connect to the ssid for wifi.
- FURRYe38Apr 24, 2025Guru - Experienced User
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message- rscheinApr 24, 2025AspirantChecked. Not on. The building internet (condo) got knocked down too. (Non orbi, but netgear) plus the California matching problem. Have not asked if that self repaired, too early.
Plus not apple devices.- FURRYe38Apr 24, 2025Guru - Experienced User
Check the front LED on the RBR next time. If PINK, means the RBR isn't getting any internet services.
OFF means it's normal.
