DavidWeller
Oct 10, 2023Aspirant
Orbi 850 BTTV Box displays IPC6023
Replaced ASUs mesh with Nethear Orbi 850 plus 1 satellite. Everything works fast and stable but for life of me I cannot get the BTTV box to display streamed tv channels just get error IPC6023 all the...
Oct 10, 2023Guru - Experienced User
Something to contact the Mfr about this box regarding there product.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
CrimpOn
Searched for "BTTV Box error IPC6339" and found a number of discussions. This one mentions IGMP. (This was talking about a Ubiquiti router, but IGMP seems to be the topic.)
https://www.drewblog.com/bt-tv-ubiquiti/
IGMP is mentioned on page 87 of the RBR850 user manual.
https://www.downloads.netgear.com/files/GDC/RBK852/RBK852_UM_EN.pdf
If other apps on the BTTV box work correctly, do they provide access to the same programming?
- DavidWellerOct 11, 2023AspirantEnabled in router but still doesn’t work. No idea how to specify a vlan port but note there are a few for French TV etc
