DavidWeller
Oct 10, 2023Aspirant
Orbi 850 BTTV Box displays IPC6023
Replaced ASUs mesh with Nethear Orbi 850 plus 1 satellite. Everything works fast and stable but for life of me I cannot get the BTTV box to display streamed tv channels just get error IPC6023 all the...
Oct 10, 2023Guru - Experienced User
Something to contact the Mfr about this box regarding there product.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
DavidWeller
Oct 11, 2023Aspirant
Orbi connected direct to BT open reach fibre modem.
Orbi 850 running V4.61.4.3_2.3.12 firmware
Cable between BT open reach is same that’s been there for 18 months with BT home hub but swapped out for a cat 6e cable still no difference
Don’t understand why a £50 BT router is able to work when an £700 system won’t!
