DavidWeller
Oct 10, 2023Aspirant
Orbi 850 BTTV Box displays IPC6023
Replaced ASUs mesh with Nethear Orbi 850 plus 1 satellite. Everything works fast and stable but for life of me I cannot get the BTTV box to display streamed tv channels just get error IPC6023 all the...
DavidWeller
Oct 11, 2023Aspirant
Orbi connected direct to BT open reach fibre modem.
Orbi 850 running V4.61.4.3_2.3.12 firmware
Cable between BT open reach is same that’s been there for 18 months with BT home hub but swapped out for a cat 6e cable still no difference
Don’t understand why a £50 BT router is able to work when an £700 system won’t!
Oct 13, 2023Guru - Experienced User
Id try the new FW:
After it's loaded up on the RBS first then RBR lastly, power OFF the system for 1 minute, including the ISP modem, then back ON with the ISP modem, then RBR and RBS lastly.
- DavidWellerOct 14, 2023AspirantHi I have updated router and satellite
Rebooted optical modem and also BT TV box but still the same. Do I need to connect BT box via the dedicated IoT WiFi band? Thanks- FURRYe38Oct 17, 2023Guru - Experienced User
Something to ask the ISP about since that's there equipment.
