Kami-h2o
Jan 30, 2022Follower
Orbi 850 compatibility with Verizon 4G LTE Home Internet
Is Orbi 850 mesh wifi compatible with the 2022 Verizon 4G LTE Home Internet gateway modem/router ? If so, how did you configure the Verizon LTE gateway and the Orbi 850 router ?
Jan 30, 2022Guru - Experienced User
Not sure about the verizon device as this is a netgear forum but you could either put the Orbi's IP address into the Verizon's DMZ or you could put the orbi in access point mode.
