HomeUserguy
Oct 19, 2021Aspirant
orbi 850 dropping
I have on the latest firmeware and my wifi drops multiple times per day. I know its not a device as my alart drops to cell, my phone drops, and PCs loose connection. I cant find anything in the logs...
Oct 20, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try disabling AX mode on the RBR
Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Has a full reset and setup from scratch been performed?
