micks_address
May 23, 2023Aspirant
Orbi 850 port forwarding
hi folks, Trying to set up remote access to home assistant via my Orbi 850. I have set up port forwarding to my home assistant IP on port 8126 but it doesnt seem to be working. I'm on starklink i...
- May 23, 2023I got sorted. Port forwarding working fine. My router and isp IP. different. Starlink uses cgnat..
May 23, 2023Guru - Experienced User
micks_address
- FURRYe38May 23, 2023Guru - Experienced User
Please share how you got it working.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
