Dsteve
Oct 24, 2021Tutor
Orbi 850 Satellite Reboot with hardwired Backhaul
Why do i have to discount my ethernet cables for the backhaul to get my satellites to reconnect to the orbi router? This causes a major problem for my home network when i am away from home, as i ...
Oct 25, 2021Guru - Experienced User
"Why do i have to discount my ethernet cables" What do you mean by Discount? Do you mean disconnect?
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
- DsteveOct 25, 2021Tutor
Ooops yeah disconnect, got to love that auto-correct!!!
V4.6.3.16
Netgear CM1000 (mine not xfinity's)
5000Sqft
router on main floor, 1st satellite in basement and the 2nd satellite on 2nd floor, satellites are around 30 feet from router.
Netgear CM1000>>>>Dlink DSR250>>>Netgear GS116
Dlink DSR250>>>Orbi RBR850 (connected to WAN port) >>>netgear GS116 (hardwire backhaul)
Satellite 1 RBS850 >>>netgear GS116 (hardwire backhaul)
Satellite 2 RBS850>>>netgear GS116 (hardwire backhaul)
Hope that makes sense!!!
Just noticed basement Satellite has disconnected, not sure why. :(
Thanks
- FURRYe38Oct 26, 2021Guru - Experienced User
Is the RBR in router or AP mode. I see you have a router in front of the RBR.
What happens if you disable 2.4Ghz AX mode on the RBR?
Set CTS values to 2347 on the RBR.
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
- DsteveOct 29, 2021Tutor
Ok both satellites discounted sometime in the last 12 hours, rebooted both satellites and still would not reconnect with the ethernet cables connected. Once the ethernet cables were disconnected the satellites would hookup and i was then able to reconnect the ethernet cables to get my backhaul back.
I had already rebooted everything on the network including the modem before this disconnect.
