jzs
Mar 10, 2022Tutor
Orbi 850 Satellite (wireless) went offline and will not reconnect to Router
I have an ORBI RBK843S AX5700 purchased from Costco a few months. Installed with one wired satellite and one wireless. All was fine until the other night. The one wireless satellite went offline from...
Mar 10, 2022Guru - Experienced User
did you try factory resetting the satellite? Push and hold reset for 7-15 seconds while powered on?
also, does it show in the primary router (not through the app) but through the browser? there should be a disconnect button you can hit through that method.
If that doesn't help, try factory resetting the whole system. Maybe the update (just released a couple days ago) caused issues with old settings.
- jzsMar 10, 2022Tutor
One more data point. I had a mini-wifi AccessPoint plugged into the satellite because I needed to broadcast an SSID at 24GHz only for a wifi thermostat. It's default network was 192.168.10.1. I unplugged it and power cycled the satellite and it came up and connected wirelessly. Problem solved. The AP was, no doubt, acting as a DHCP server on both ethernet connections and the ORBI picked it up and ran with it, perhaps after a power glitch/reboot.
- plemansMar 10, 2022Guru - Experienced User
Glad it was a simple fix!
If you mark it solved, it helps keep others from trying to fix an already fixed issue.
Plus it might help others that run into similar issues!
Again glad it worked!
(someone might post after me about the importance of making backups) ;)
- FURRYe38Mar 10, 2022Guru - Experienced User
Never hurts to have one on hand. Saves time if a reset is needed.
