Chuck_M's avatar
Chuck_M
Mentor
Sep 29, 2024
Orbi 850 Speed Test
My Orbi RBR 850 and 3 satellites work great... however, perhaps someone can shed some light on a question:
This week I upgraded my internet service from 1Gig to 2.5 gigs.  I also added a 2.5G switch after the Orbi to service all wired devices.
The input to my Orbi is in the WAN port which is labled as 2.5Ghz.
My speed test (From the router configuration web page) reports speeds off 977M up and 113M down.
Questions:
1.  When running the speed test from the router page (Advanced | Setup | Speed Test:  Is that testing the true speed at the router or is it on the client that is running the web browser?
2.  I understand that the input (WAN port) can be 2.5G, but are the other four LAN ports (output) restricted to 1.0G?
3.  Based on the above answers, I may be forced to upgrade to something such as the 770 or 970...  I understand that the 850 satellites are compatible with the 770/970 (at previous wifi speeds), which would be fine as I am more interested in the connection speeds of machines that are hard wired.  Are the LAN ports of the 770 and/or 970 2.5G or higher?
Please let me know if you have any knowledge on the above!
Appreciate it.
  • CrimpOn's avatar
    CrimpOn
    Running a Speed Test on the Orbi web interface (or the Orbi 'app') gives the results of a program running on the router itself.  If the results are 977 up and 113 down, something is seriously wrong.  The recommended step is to connect a computer directly to the Internet Service Provider (ISP) device with an Ethernet adapter which supports at least 2.5G and run Ookla Speed Test on it.
    Yes, the Orbi 850 LAN ports are all gigabit Ethernet.  Connecting a 2.5G Ethernet switch to one of these ports accomplishes nothing.
    Netgear has not yet updated their web site to show which satellites are compatible with the 770 product.  It appears that the 850 satellites are not compatible with the 970 product:
    https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
    As far as LAN ports, the Product Data Sheet for each product shows their LAN ports are 2.5G:
    https://www.downloads.netgear.com/files/GDC/RBE973S/RBE973S_TS.pdf
    https://www.downloads.netgear.com/files/GDC/RBE772/RBE772_TS.pdf
    • Chuck_M's avatar
      Chuck_M
      Mentor
      Thanks for this rundown; I have been (slowly) working through which "dominoes" have to fall/be replaced to get full 2.5G across my network (and whatever speeds may be available in the future).
      I will definitely try the direct-wire test you are suggesting.
      I think I have convinced myself the 970 is the way to go... especially since my current 3 satellites are wired backhaul and it would just be a matter of unplugging the old and plugging in the new -- and then setup with the previous SSID, settings, etc. -- an in-place upgrade.
      I have owned quite a few of the ORBI series, and am considering biting the bullet to future-proof my architecture.
      Interestingly enough, Best Buy will give you 15% off the 970 if you take your old router in when purchasing.
      Thanks for your response.
      Any comments you may have on the 970 are appreciated.
