rew123's avatar
rew123
Follower
Feb 15, 2021
ORBI 850 TCP Destination Port 443?
I am attempting to hook up a wifi module which monitors a backup sump pump that needs to communicate with a server via the internet. In speaking to the pump manufacturer, I need to endable TCP Destination Port 443. Can anyone tell me the steps to confirm that it is enabled or how to enable that port? Thanks
  • > ORBI 850 [...]
       What's the actual model number?  Look for "Model" on the product
    label.  Firmware version?  Connected to what?
    > I am attempting to [...]
       Are you having some actual problem?
       "attempting" is not a useful problem description.  It does not say
    what you did.  It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
    > [...] In speaking to the pump manufacturer, [...]
       Should I know which?  One of us might want to see some documentation.
    > [...] I need to endable TCP Destination Port 443. [...]
       I don't know what that means.  Whose "Destination"?
    > [...] needs to communicate with a server via the internet. [...]
       That's a little vague, too.
       Does your (unspecified) "a wifi module" need (A) to establish an
    outgoing connection to some outside-world server which is operated by
    the (unspecified) "the pump manufacturer", or (B) to accept some kind of
    incoming connection from the outside world?
       (A) should require no special effort.  Whenever you use a web browser
    with an "https://xxxxx" URL, that web browser is making a TCP connection
    to that web server using port 443.  There's no need to "enable" anything
    to make that work.  (B) is more complicated, but also less likely.
       General advice: You might have more success if you described
    (clearly) the actual problem which you are trying to solve, rather than
    asking how to implement some particular "solution" ("enable that port")
    which may have little or nothing to do with the actual problem (whatever
    it might be).
  • FURRYe38's avatar
