StOlive
Jan 23, 2022Guide
Orbi 850 throttles download speed
Hi All, i have RBK850 and 1 RBS850. I am based in Australia and have NBN HFC. I am currently on a 1gig download/40mbps upload connection. Up until few weeks ago i was getting download speeds of 800+...
Mikey94025
Jan 23, 2022Hero
StOlive wrote:<> The WAN shows 100m/full, however the same Cat6 cable straight from the NBN modem gives me 800+mbps to my pc
If orbilogin.com's Advanced / Internet Port / Show Statistics says your WAN port is 100m/Full instead of 1000M/Full then we need to focus on fixing that. Do try a different cable and fiddling with things (even though the same cable works from modem->PC). Maybe your Orbi's WAN network jack has a hardware problem, which would suck.
StOlive
Jan 23, 2022Guide
Thanks Mikey94025 . Yes it does say that 100 .. instead of 1000. I tried a different cable but same issue. Should i go back to Netgear support and tell them that ?? If its an issue with the port and Netgear's claimed warranty is 2 years.. do i still have to pay to talk to support ?? I bought this Router around 6 months ago.
Also a quick question.. with this forum.. is it possible to interact straight from emails or do i have to login each time to the forum ?
- Mikey94025Jan 24, 2022Hero
StOlive wrote:Thanks Mikey94025 . Yes it does say that 100 .. instead of 1000. I tried a different cable but same issue. Should i go back to Netgear support and tell them that ?? If its an issue with the port and Netgear's claimed warranty is 2 years.. do i still have to pay to talk to support ?? I bought this Router around 6 months ago.
I would talk to Netgear and try to get your product replaced under warranty if your hardware is defective (due to the network port). This is not the same as a tech support request, which is only given for the first 90 days.
This seems to be how to request warranty replacement (RMA): https://kb.netgear.com/1162/How-can-I-get-a-Return-Material-Authorization
However, before doing so verify how long your product's warranty is. There is a tool here: https://kb.netgear.com/12171/Is-my-NETGEAR-product-under-warranty. According to this page, the RBR850 warranty is one year (not 2 years), but you're still okay if you bought it 6 months ago: https://www.netgear.com/support/product/rbr850.aspx#ProductWarranty_CommonTopics. You may also consider returning to your original place of purchase, if that is also an option provided by them (some vendors like Costco are very good with that).
- CrimpOnJan 24, 2022Guru - Experienced User
No. You cannot 'reply' to the email. Click on the Link that is included in the email, which takes you to the web site, where you log in.
Being somewhat lazy, I store this web site credentials in my web browser to speed up the login process.
There may be a difference between Netgear's published warranty and consumer protection guarantees. For example, the EU has this rule:
https://www.howtogeek.com/342735/if-you-live-in-the-eu-you-probably-have-a-better-gadget-warranty/
