Retired_Member
Apr 29, 2022Orbi 850 VLAN - Can you configure VLANs with the desktop (not Insight) in AP mode?
I see that I have options in Insight but the desktop shows no LAN or WAN options in AP mode. Advanced->LAN VLAN settings or whatever...doesn't exist as an option. For some reason my satellites that...
- Retired_MemberApr 29, 2022
Makes perfect sense.
Not surprised and not disappointed. It was a corner case that really only makes sense in my world.
With the ability to connect over the MoCA I may end up just going to a wireless backhaul as anything that connects wirelessly doesn't need the speed or stability of hardwired solutions. That will eliminate the need for a VLAN.
Really appreciate your help!
Just saved me about five hours of investigation and troubleshooting.
Apr 29, 2022Guru - Experienced User
What actual router do you have? The RBK850 series doesn't support insight. That's the pro series.
And here's features disabled in AP mode
NETGEAR Orbi Whole Home Tri-band Mesh Wi-Fi 6 System (RBK853) – Router with 2 Satellite Extenders, Coverage Up to 7,500 Square Feet, 100 Devices, AX6000 (Up to 6Gbps)
https://www.amazon.com/dp/B082LZKYFL?ref=ppx_yo2ov_dt_b_product_details&th=1
Looks like it's not PRO.
Weird.
Can I do VLANs in AP mode with this model?
- plemansApr 29, 2022Guru - Experienced User
vlan's for the consumer version are for iptv/fibre setups.
Just viewing the details shouldn't have made the satellite stop working through.
Are they being used with a wireless backhaul or wired?
You folks helped me the other day on this. It was working with your help...
But I was hoping to break out the traffic that doesn't need the router traffic and send it directly to the internet using VLANs.
So I popped open the Insight app and was looking around...got to the end of the management VLAN walkthrough and it said "push config." No other options and I didn't make any changes so I pushed.
What I don't know is if the satellites weren't working before I did that. I had made no other changes so my thought is I jacked it up.
I've bounced the router and satellites with no luck. I may go ahead and resynch and see if that helps...but as they're on 3 different floors and I'm old and out of shape that's a chore. LOL.
I have the satellites going to a managed switch that's connected to a MoCA network that connects to the LAN ports on the router. (complicated...basically Satellite -> LAN side switch -> MoCA -> Router -> WAN side Switch -> WAN/LAN router -> modem -> Internet.)
