Retired_Member
Apr 29, 2022Orbi 850 VLAN - Can you configure VLANs with the desktop (not Insight) in AP mode?
I see that I have options in Insight but the desktop shows no LAN or WAN options in AP mode. Advanced->LAN VLAN settings or whatever...doesn't exist as an option. For some reason my satellites that...
- Retired_MemberApr 29, 2022
Makes perfect sense.
Not surprised and not disappointed. It was a corner case that really only makes sense in my world.
With the ability to connect over the MoCA I may end up just going to a wireless backhaul as anything that connects wirelessly doesn't need the speed or stability of hardwired solutions. That will eliminate the need for a VLAN.
Really appreciate your help!
Just saved me about five hours of investigation and troubleshooting.
Apr 29, 2022Guru - Experienced User
Again, in access point mode, vlan's are disabled. And the consumer router doesn't insight. So I'm not sure what you were clicking on or doing. Maybe you were in the standard app?
When we were helping you last time, it was with properly wiring in a wired backhaul so they connected properly.
Without knowing exactly what was clicked on, it might be faster for you to just factory reset and reinstall it.
Retired_Member
Apr 29, 2022Makes perfect sense.
- plemansApr 29, 2022Guru - Experienced User
Good luck!
