N49's avatar
N49
Orbi 850, web browser and phone app showing the wrong MAC addresses.
My main computer is windows 10 based. The firmware version for the RBR 850 is V4.6.3.16_2.0.51. The modem is a Hitron model number CGNM 2250. Cable company is Shaw cable in Canada.   I purchased an...
  • FURRYe38's avatar
    Jan 15, 2022
    Also be aware that Apple has introduced a new iOS feature thats called Private Address. When enabled on apple devices changes the MAC address seen on any router to a randsom MAC address. This is ok when travelling, however for home use, I tend to disable this feature.
    I recommend updating to v5 FW here:
    https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR850-RBS850-Firmware-Version-v4-6-7-5-Released/m-p/2182138/highlight/true#M25415
    v16 FW is known for being problmatic for most users. Were seeing better experiences with v5 FW.
    Please manually download to a local wired PC and use a web browswer to update the RBS first, then RBR lastly. You can use the RBS web page to send the FW File. I recommend after the FW is sent to the RBS then RBR and these are back to ready, Power OFF the RBS and RBR for 1 minute or longer then back ON. You might include the ISP Modem as well.
    Once the system is back online, check your devices.
    You might try changing CTS values to 2347 on the RBR.
