Richien1dad
Jan 29, 2020Aspirant
Orbi 852 extra satellites
Hi all, I have bought a triple pack orbi 853 witch comes with one router and two satellites but I’m still getting area in my home with low Wi-Fi or no Wi-Fi ( large home) so basic question is can I ad...
- Feb 14, 2020
Glad it's working for you now. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
Jan 30, 2020Guru - Experienced User
I have a 5000sq ft home and initially started with just one RBS then got 1 more. Even with just 1 RBS, it was enough for great wifi coverage. Adding more RBS maybe too much however. Placement and distance is key here.
NG hasn't mentioned how many RBSs can be connected. We presume more.
Richien1dad
Jan 30, 2020Aspirant
Hi thank for reply, my home is 7150sq feet but well built with brick walls, i didnt know about the 30 feet bit so i will also try that, my other issue is the server room has a door on in and the ORBI router is in there so that may not help,
just as a question thou do you know if i can add an extra satelite to teh system? if so i cant seem to find anywhere to buy on on its own they are all in a two or three bundle at moment
- FURRYe38Jan 30, 2020Guru - Experienced User
ANy chance of moving the RBR outside of the server room into a more central location on a main floor of the home.
Haven't seen anyone with more than two RBSs currently. I have two and they are working well for my 5000sq ft home.
IF you get more, please let us know how it all works. NG officially supports 3 RBS on there ORBI AC model. I presume maybe same or ORBI AX. However some users reported having 6 RBS on RBR50 series ORBI. No idea if that many would work on ORBI AX. Anything is possible.
- Richien1dadJan 30, 2020AspirantThanks you so much for helping, I’m going to have a go Saturday on moving the ORBI router out if that room to my entrance hall
I’ve also just order a two pack (one router and one sat) so I can use the sat from that pack
So I’ll let you know how that work
Once again many thanks- FURRYe38Jan 30, 2020Guru - Experienced User
:smileywink:
