Stahl101
May 16, 2022Guide
Orbi 852 losing connection to wifi constantly
Hi All, I am Constantly losing wifi connection on my Orbi RBK852. Units which are with cable works fine. In the App the RBR850 changes between online and offline. RBS850 (satellite) is online a...
May 16, 2022Guru - Experienced User
What's the status show on the RBS web page.
There are some known issues happening with Orbi app which maybe falsely reporting router operation.
Stahl101
May 16, 2022Guide
I saw it after i wrote the massage, and tried to the "new" downgrade 4.6.3.16 and now its all F..... no Wifi at all.
- FURRYe38May 17, 2022Guru - Experienced User
Id you first downgrade the RBS then the RBR lastly?
Does pressing the reset button for 15 seconds then release and connect a wired PC to the RBR should bring up the setup wizard at HTTP and 192.168.1.1 in a web browser?
- Stahl101May 18, 2022Guide
I tried to factory reset, and got to install everything again, without any changes, so i wouldnt recomend that, knowing that it's only is a waste of time. (in my case)
I downgraded to the "new downgrade" NG posted and still nothing changed (RBS first, RBR second). Ill wait, and to see if Ng figures something out, otherwise its another brand i have to use.
Thanks for your help and reply.
- FURRYe38May 18, 2022Guru - Experienced User
I recommend you reach out to NG support and ask for additional help and information on this:
https://my.netgear.com/support/contact.aspx
