Stahl101
May 16, 2022Guide
Orbi 852 losing connection to wifi constantly
Hi All, I am Constantly losing wifi connection on my Orbi RBK852. Units which are with cable works fine. In the App the RBR850 changes between online and offline. RBS850 (satellite) is online a...
Jun 14, 2022Guru - Experienced User
Are you using CAT6 cabling in between the RBR and RBS?
If all cabling is GOOD, then direct connect RBS via ethernet to the back of the RBR should work and not effect internet services. If it is, there is a problem in cabling or something between the RBR and modem. Odd issue here.
Stahl101
Jul 11, 2022Guide
I got working a bit more with the issue, and finally got connected with genvex. They told me that they had the experience before, and the costumer talked with internet supplier and they solved it together, what they did he didn't know. "great"
When i Connect genvex the issue with bad internet starts 24-48 hours after i connect it. what i have done now is making the IP on genvex static, and then wait.
I think the issue in this forum is solved, as it is a problem with some hardware in my house.
Thanks for the help.
- FURRYe38Jul 11, 2022Guru - Experienced User
Hope you can get it figured out.
