2564orange
Jul 29, 2020Follower
Orbi 852 power adapter
I purchased a Orbi RBK 852 sometime ago. However, the voltage adapter can only be used at 100v. Other Netgear router comes with a free voltage adapter, so I'm not sure why this is the only one. I am wondering if I can replace the 100v adapter with a free voltage one.
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax#
I would contact NG support for help on this.
Good Luck.
2564orange wrote:I purchased a Orbi RBK 852 sometime ago. However, the voltage adapter can only be used at 100v. Other Netgear router comes with a free voltage adapter, so I'm not sure why this is the only one. I am wondering if I can replace the 100v adapter with a free voltage one.
Amazon sells an "all purpose" power supply that lists the 850 series Orbi among the products it supports:
- ekhalilMaster
You might want to consider this opinion: https://community.netgear.com/t5/Orbi/RBK20W-Power-Supply-Moving-US-to-Europe/m-p/1807130/highlight/true#M71841 :)
