dglsmcd_USMC
Feb 15, 2020Luminary
Orbi 852 Wireless Smart Connect with PS4 Pro
This post is just for future information to provide a solution to a potential problem with the Smart Connect and the PS4 Pro. When I switched over to my Orbi 852 (latest firmware and hard reset post ...
- Feb 27, 2020
With the PS4 Pro in the 5GHz only mode for a wifi frequency and the Orbi 852 (smart connect only) these were the results:
When I tried to login the Orbi 852 network the PS4 Pro refused the connection repeatedly-I then observed the network status page of the PS4 Pro and it would pickup the 5GHz signal from the Orbi 852 for approx 5 sec but then drop-this continued without interuption.
UPDATE: Beta firmware provided by NG yesterday has resolved this issue to include re-establishing the PS4 Pro connection upon startup from standby or fully off without having to provide wifi login information. Preliminary results look good and further analysis using the different wifi frequency modes for the PS4 Pro will be posted. FYI PS4 Pro does not support WPA3 at this time.
Feb 19, 2020Guru - Experienced User
Interesting that the PS connected to 5Ghz to the ORbi in AP mode and and not in router mode.
I presume the ASUS routers wifi was disabled? I have this same router as well.
What FW version are you using on the ASUS Router?
dglsmcd_USMC
Feb 19, 2020Luminary
My bad, I had the PS4 Pro on the ASUS 5GHz wireless network-disabled the ASUS radios and original issue still exists-had to force PS4 Pro out of auto to 2.4GHz to retain network connection to the Orbi 852. I am going to try to connect to the ASUS radios but in smart connect mode instead of separate radios and see if the PS4 Pro picks up and retains a 5GHz signal.
With the PS4 Pro in the auto mode for wifi frequency and the ASUS wireless mode in smart connect these are the results:
Initially when I chose the ASUS wireless network the PS4 Pro automatically chose the 2.4GHz wifi frequency. When I shutdown the PS4 Pro completely and turned it back on the PS4 Pro automatically chose the 5GHz wifi frequency without dropping the wifi connection and having to re-enter the network login info. Smart mode worked flawlessly with the ASUS connecting to the PS4 Pro.
With the PS4 Pro in the auto mode for wifi frequency and the Orbi 852 (smart connect only) these are the results:
Intially when I chose the Orbi wifi network the PS4 Pro would only capture the 2.4GHz wireless network. The PS4 Pro was then shutdown completely and upon startup lost the wifi connection to the Orbi 852 and required you to login with your network credentials-this is a recurrent theme with the Orbi 852 and the PS4 Pro in auto mode.
Solution for PS4 Pro connecting to ASUS wireless network in smart connect mode: no work arounds required
Solution for PS4 Pro connecting to Orbi 852 (smart connect only): have to force the PS4 Pro to 2.4GHz only in order to retain network login info when PS4 Pro is shutdown completely and then restarted. Connection to 5GHz (auto or forcing 5GHz) on the PS4 Pro not possible with the Orbi 852.
ASUS GT-AX11000 firmware 3.0.0.4.384_7979
- FURRYe38Feb 19, 2020Guru - Experienced User
Thanks for this detailed info. I would open a support ticket regarding this and give this information to NG. Seems like there could be some tuning done in FW hopefully.
- FURRYe38Feb 23, 2020Guru - Experienced User
Thanks for letting me know the PS4 behaves correctly with a RBK50 in place of the RBK850.
Post all information here in your thread so as to keep all the information centralized. No need to send me any PMs.
Keep in touch with Blanca. Shes trying to contact you.
FURRYe38 wrote:Thanks for this detailed info. I would open a support ticket regarding this and give this information to NG. Seems like there could be some tuning done in FW hopefully.
- Blanca_OFeb 20, 2020NETGEAR Employee Retired
- dglsmcd_USMCFeb 27, 2020Luminary
- FURRYe38Feb 28, 2020Guru - Experienced User
Was this beta from NG something different then what was posted in the beta forum I presume?
Glad it's working better.
Ya WPA3 hasn't been fully finalized yet. Hopefully they will get WPA3 stuff ironed out this year.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
- dglsmcd_USMCFeb 29, 2020Luminary
The beta firmware (RBR/RBS850-V201-signed 20/02/2020) was received via NG email which has not been posted on the beta forum. Hopefully this firmware will be a part of the next public release as it appears the smart connect is functioning correctly. As I mentioned before there is still some testing to do so keep your fingers crossed. Bottom line progress is being made-definitely the right direction.
- dglsmcd_USMCMar 03, 2020Luminary
UPDATE: Continuing with the testing with beta firmware and the PS4 Pro in auto mode (wifi frequency), the PS4 Pro would capture the 2.4GHz frequency initially but would then transition to the 5GHz frequency and retain that. Used the PS4 Pro for several hours without any dropouts or issues. Shutdown the PS4 Pro completely and restarted-the connection to the Orbi 852 (smart connect only) was retained and the PS4 Pro network status reflected 5GHz. All observations/measurements with the PS4 Pro and the Orbi 852 (smart connect only) were accomplished without any physical displacement of either unit for consistency (Orbi RBS 850 (satellite) 30 plus feet from RBR 850 at all times).
- FURRYe38Mar 03, 2020Guru - Experienced User
Great to hear. Glad the beta FW is working better for the PS4. Thanks for testing and letting us know.
Enjoy. :smileywink:
