dglsmcd_USMC
Feb 15, 2020Luminary
Orbi 852 Wireless Smart Connect with PS4 Pro
This post is just for future information to provide a solution to a potential problem with the Smart Connect and the PS4 Pro. When I switched over to my Orbi 852 (latest firmware and hard reset post ...
- Feb 27, 2020
With the PS4 Pro in the 5GHz only mode for a wifi frequency and the Orbi 852 (smart connect only) these were the results:
When I tried to login the Orbi 852 network the PS4 Pro refused the connection repeatedly-I then observed the network status page of the PS4 Pro and it would pickup the 5GHz signal from the Orbi 852 for approx 5 sec but then drop-this continued without interuption.
UPDATE: Beta firmware provided by NG yesterday has resolved this issue to include re-establishing the PS4 Pro connection upon startup from standby or fully off without having to provide wifi login information. Preliminary results look good and further analysis using the different wifi frequency modes for the PS4 Pro will be posted. FYI PS4 Pro does not support WPA3 at this time.
dglsmcd_USMC
Feb 29, 2020Luminary
The beta firmware (RBR/RBS850-V201-signed 20/02/2020) was received via NG email which has not been posted on the beta forum. Hopefully this firmware will be a part of the next public release as it appears the smart connect is functioning correctly. As I mentioned before there is still some testing to do so keep your fingers crossed. Bottom line progress is being made-definitely the right direction.
Feb 29, 2020Guru - Experienced User
Ok, thanks for letting us know. I'll ask to see if new versions canbe posted to the beta forum as time goes on.
Glad its working better now.
Enjoy. :smileywink:
