dglsmcd_USMC
Feb 15, 2020Luminary
Orbi 852 Wireless Smart Connect with PS4 Pro
This post is just for future information to provide a solution to a potential problem with the Smart Connect and the PS4 Pro. When I switched over to my Orbi 852 (latest firmware and hard reset post ...
- Feb 27, 2020
With the PS4 Pro in the 5GHz only mode for a wifi frequency and the Orbi 852 (smart connect only) these were the results:
When I tried to login the Orbi 852 network the PS4 Pro refused the connection repeatedly-I then observed the network status page of the PS4 Pro and it would pickup the 5GHz signal from the Orbi 852 for approx 5 sec but then drop-this continued without interuption.
UPDATE: Beta firmware provided by NG yesterday has resolved this issue to include re-establishing the PS4 Pro connection upon startup from standby or fully off without having to provide wifi login information. Preliminary results look good and further analysis using the different wifi frequency modes for the PS4 Pro will be posted. FYI PS4 Pro does not support WPA3 at this time.
dglsmcd_USMC
Mar 03, 2020Luminary
With the PS4 Pro in the auto mode for wifi frequency and the Orbi 852 (smart connect only) these are the results:
Intially when I chose the Orbi wifi network the PS4 Pro would only capture the 2.4GHz wireless network. The PS4 Pro was then shutdown completely and upon startup lost the wifi connection to the Orbi 852 and required you to login with your network credentials-this is a recurrent theme with the Orbi 852 and the PS4 Pro in auto mode.
UPDATE: Continuing with the testing with beta firmware and the PS4 Pro in auto mode (wifi frequency), the PS4 Pro would capture the 2.4GHz frequency initially but would then transition to the 5GHz frequency and retain that. Used the PS4 Pro for several hours without any dropouts or issues. Shutdown the PS4 Pro completely and restarted-the connection to the Orbi 852 (smart connect only) was retained and the PS4 Pro network status reflected 5GHz. All observations/measurements with the PS4 Pro and the Orbi 852 (smart connect only) were accomplished without any physical displacement of either unit for consistency (Orbi RBS 850 (satellite) 30 plus feet from RBR 850 at all times).
Mar 03, 2020Guru - Experienced User
Great to hear. Glad the beta FW is working better for the PS4. Thanks for testing and letting us know.
Enjoy. :smileywink:
